WHICH INJECTORS?! for 383
Old 07-12-2013, 12:29 PM
lucahemi's Avatar
Question WHICH INJECTORS?! for 383
Decided to get 32, 36 or 42lb injectors for my newly finished 383 lt1 build. The part that is confusing me is which brand/make injectors i should get and what will work! I see bosch, delphi, TRE, and even ford racing injectors. will the ford 39lb injectors work? Also, what is your guys thoughts on used injectors such as these:
USED:
http://www.ebay.com/itm/BOSCH-32LB-320CC-FORD-CHEVY-PONTIAC-TURBO-FUEL-INJECTORS-0-280-155-759-SET-8-/330949446095?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item4d0e1fc9cfFORD 39lb:
http://www.ebay.com/itm/FORD-MUSTANG-COBRA-BLUE-39LB-FUEL-INJECTORS-SUPERCHARGER-TURBO-42LB-39-440cc-/121140440720?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c34886e90&vxp=mtr
Old 07-12-2013, 01:16 PM
ahritchie's Avatar
I put 42# injectors in my 383 build which is plenty for what it is, I would make sure they are flow tested and cleaned if you are buying used ones.
Something like these:
http://www.ebay.com/itm/Chevrolet-1986-02-LS1-LT1-42-lbs-hr-Set-of-8-Plug-Play-Fuel-Injectors-/161064903419?pt=Race_Car_Parts&hash=item25803762fb&vxp=mtr
http://www.ebay.com/itm/TRE-42LB-Fuel-Injectors-Fit-Bosch-Chevy-Ford-V8-LS1-LT1-5-0L-EV1-LSX-440cc-min-/321142898626?pt=Motors_Car_Truck_Parts_Accessories&hash=item4ac59bbfc2&vxp=mtr#ht_4421wt_934
Old 07-12-2013, 04:25 PM
RamAir95TA's Avatar
Lucas/Delphi injectors.
You don't list any details of your build so it's hard to suggest a flow rate. Having said that the 383 I build 4 years ago used Lucas/Delphi 42#s.
Old 07-12-2013, 04:56 PM
96capricemgr's Avatar
Most 383 even are fine with 30lbs. Yes that goes over the antiquated 85%DC rule, it might
Old 07-12-2013, 10:57 PM
lucahemi's Avatar
those ones from tlf look nice but the starting bid is at 190 bucks. i was looking to spend around 150-200 bucks. The ford ones i posted are 39lb and came off a car with only 7k miles on it and were flow matched. what do you guys think about these?
Old 07-13-2013, 08:34 AM
If you are choking on $200 for injectors then how much of a joke is the stroker build? Cast Eagle crank? Maybe some lead pistons? 10:1 compression?
Far as what injectors to get, there is more to injectors than just the size rating, ask your tuner what he likes because it will be easier for him to dial it in if he is familiar with the stuff you buy.
Old 07-13-2013, 10:54 AM
BALLSS's Avatar
bingo....OP a variety of "#" will "work" but as Caprice notes ask your tuner
FWIW I have Ford SVO 30 lb in my 383
Old 07-13-2013, 11:14 AM
9-Second Club
Ed Wright's Avatar
Talk to your tuner. There is more to it than typing in the lbs per hour flow rating.
He has to have tuned the brand & flow rate in person to have developed injector off set tables, etc, for that particular injector. Buy good injectors, not off-brand cheap ****. Bosch, Delphi, Lucus only. Accel are now Bosch. Used to be junk.
Ford are Bosch.
Required flow rate, like many other things, depend on power levels. Around 450 rwhp will be OK with 30 lbs. 500+ need more.
And, that 85% duty cycle limit so many talk about is simply Internet message board bull ****.
Old 07-13-2013, 01:04 PM
WS Sick's Avatar
I'm running SVO 30s in my 383, and yes at the top of the gears it surpasses 90%, but only for a moment.
Old 07-13-2013, 01:13 PM
9-Second Club
Ed Wright's Avatar
Your OK.
Old 07-16-2013, 01:15 PM
Fazz73jr's Avatar
Hell if your on a tight budget get grand prix gtp injectors. There 36# injectors and can find em almost anywhere used for dirt cheap. Thats what im running...
Old 07-16-2013, 02:19 PM
93M6Formula's Avatar
I'm not sure the '03-'04 Cobra injectors have the same connector, (can't remember the name) but I know the GTP, Buick Ultra, Bonneville SSEI injectors will work. Any S/C 3.8 that is.
Old 07-16-2013, 05:41 PM
BIGCAT7274's Avatar
for a n/a combo it maybe fine. but i would not run a p/a setup that close to the edge.
Old 07-16-2013, 06:33 PM
9-Second Club
Ed Wright's Avatar
And, you were taught this where?
And NA or boosted make this different how?
Do you know that duty cycle you see on a scan tool is never correct at higher RPM? That it is only a calculation, not an actual measurement?
Try checking that actual injector pulse width with a fast DSO, and you will find the scan tool numbers are way high. Know what a DSO is? Digital Storage Oscilloscope. You need afast one, cheap ones update too slow.
Look at the injector pattern, and measure the actual pulse width. 85% on a scan tool is usually well under 80%.
Old 07-17-2013, 03:04 PM
BIGCAT7274's Avatar
Try checking that actual injector pulse width with a fast DSO, and you will find the scan tool numbers are way high. Know what a DSO is? Digital Storage Oscilloscope. You need a fast one, cheap ones update too slow.
well arnt you just a condescending know it all.
Old 07-17-2013, 03:29 PM
9-Second Club
Ed Wright's Avatar
Not trying to be condecending, trying to teach you something.
Old 07-17-2013, 03:53 PM
BALLSS's Avatar
Sir...I will be brief.
Mr Wright is beyond qualified to the subject in this thread. If you don't know his credentials, many do.
Old 07-18-2013, 10:40 AM
Mystery Bird's Avatar
I ran 30's last year in my new 381 with the DC in the high 90's at 6500 RPM's but wideband did not show a lean condition. I went with 36's this year. I get the same reading on the wideband but the DC is now in the low 80's. Just saying.
Old 07-18-2013, 10:52 AM
9-Second Club
Ed Wright's Avatar
Lots of actual NHRA racers run their actual, not scanner, duty cycles in the mid-high 90s with no issues.
Many people preaching differently also sell injectors.
Btw, there is power to be had raising fuel pressure with smaller injectors than just larger injectors.
Ie: 36 lb injectors at 60 psi flow 42lbs, but made 5 more rwhp in my car than 42 lbs at 45 psi. A-B-A testing (Back-to-back-to-back), same day without moving the car off the dyno. Smaller injectors at higher pressures atomize the fuel better. Main reason why GM went to 60 psi with the Vortec & LS engines.
Old 07-18-2013, 05:34 PM
and several very bright guys around here have found the 60ft times to be better with the smallest possible injector. Best I can guess is it has to do with better atomization at lower rpms instead of a huge injector making a huge short squirt.
Quick Reply: WHICH INJECTORS?! for 383
