clutch problem
clutch problem
my car wont run ive bled it and it wont go into gear but if i press the clutch pedal and try to shift all it does it like kinda rocks forward but wont go into gear...and another thing when i have the car on. the pedal is not that hard do i still need to bleed more? or do i need a new clutch and pressure plate
Use a Mighty Vac Worth the price.. I had Problems bleeding mine with My GF Pumping & Holding.. Not worth the hassle, use a mighty vac and bleed from the reservoir.. Took a 45 PITA to a 30 sec Happiness.. Good Luck
nope i just changed only the slayer and master cylinder and holes after that the car didnt want to catch gear anymore im bleeding it with the gun and its going pretty good i just dont know if i should continue bleeding cause its pretty hard when its off but when its on its a little loose or if i need a new clutch and pressure plate...just a week ago we looked at the pressure it looked good the teeth were all even and the clutch looked good too
