94 camaro z28 codes any know possible problem?
i have a 1994 camaro z28 scanned these codes can anyone make sense of what the main problem might be?
dtc; 42,43,44,45,51,53,54,55
the alternator was tested and all components were good and The battery was tested and load tested and was good and checked the junction terminals for positive and negitive cleaned them also front grounds cleaned and tighten. also cleaned the main positive and negitive terminals. There is the coil and ground next to the passanger o2 that i have not checked yet.
could i have a fried ECU because i touched it after 5 min of start up it was hot to the touch.
thanks everyone,
thanks everyone,
I would say clear the codes and see what comes back. 54 is not even a valid code for your car.
[edit] Ok, I see you already have a thread going for this problem. https://ls1tech.com/forums/lt1-lt4-m...hat-might.html
Why start another? It only reduces your chances for good responses.
yea I know im just frustrated because this just is pissing me off. im trying to get feed back with anyone who had the same or similar problems.
I have an innova scanner and it tells me to refer to the Chevy manual for clearing codes what is the process because if its disconnecting the battery for 30 I have tried that and no effect. I thank you for helping me
