guys with long tubes and ory
I'm sure I'll get **** for this, but I swapped everything from my 94' z into my 99' roller (had the time and boredom, plus 99' body is in much better shape).
everything thing is a perfect fit except for the fuel lines.
They weren't touching on the z28 body at all, now they want to rest on the y-pipe after swapping.
It is a pacesetter ory.
could I cut and reroute them using a flaring tool and flare fittings safely?
The area the curves outwards from the tunnel is the part that is touching btw.
Maybe I just need to pull everything off and try to find the sweet spot, because there can't be enough difference in the bodies to cause this issue.
I'm thinking about just wrapping the y in that area, and then wrapping the lines with heat resistant tape/wrap
