Great price for OptiSparks!
ProComp Optispark for LT1/Lt4
CHEVY LT1 10000 SERIES DISTRIBUTOR
OEM Replacement Distributor is designed for enthusiasts that are serious about performance.
precision tolerances, high strength and incredible endurance.
Under the brass terminals of the cap and rotor is an extremely accurate Optical eye which never requires adjustment.
The 1/2' steel shaft that spins the Rotor is guided by a sealed ball bearing and long sintered bushing.
This combination provides stable timing signals and spark delivery at any RPM.
1 year warranty!
Only $159.95 http://www.saccitycorvette.com/LT1-SBC-IGNITION.html
1 year warranty!
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
So, it's a hallyspark? ?? Is that even possible? This sounds more like a description used for a normal distributor. In that case, it makes the marketing attempt a bit odd (in that it has the wrong information).
The description is not unlike many of the other low buck optis out there (except for the hall effect thing). I guess there will need to be some guinea pigs out there to give some feedback.
I believe that hall-effect sensors produce a square wave, so it may be possible to get the necessary signal without any kind of conversion. I will be amazed if this distributor actually has something like that inside.
I'd like to see this project completed: https://ls1tech.com/forums/lt1-lt4-m...r-preview.html - It could be named the 'magna-spark' since it has magnetic pickups, but 'opti-eliminator' works too! Maybe Wicked94Z will see this and give us an update on that thread.
Hello,
We are sorry about the description, It was what we received from procomp themselves. Come to find out, it was a description for a standard sbc distributor. we have pictures of the inside and out of the actual procomp opti. It uses an optical eye like the factory optispark.
__________________
We asked and all we were told is that it is made offshore.
But it has a 1 yr warranty.
Thanks
Christian
Thanks
Christian
__________________
Bump for the new week!
__________________
