94 z28 fuel pressure numbers are weird pump failure
I just tested my cars fuel pressure due to finding out i had a dtc of lean/ rich conditions to the 02 sensors.
is my fuel pump starting to fail? also getting a fuel pump short in wiring code
at idle 35 psi
under rpm load 26-28
i know spec is suppose to be 42psi at idle correct?
thanks,
at idle 35 psi
thanks,
i have not checked that yet, but it starves for fuel under 2,500 rpm and no leaking or plugged injectors checked that a few days ago. but will try to test it later for how u said to do it.
