clutch question help plz
i put a new mast cylinder and slayer holes and still wont go into gear could it be my clutch is no good? everything is in the right order as it should go in
Village Troll
Is this you?
https://ls1tech.com/forums/lt1-lt4-m...l#post17571032
It's a slave cylinder. Not a slayer. Slayer is an evil metal band out of the 80's who loves to hail Satan.
Is the above post the same problem you're posting again? If you know everything is the way it should go it reads like it's time to remove the transmission to see if there is a mechanical problem. At least check to see your clutch fork is seated correctly by first pulling on it to see if it disengages from the throwout bearing and pushing it back in.
ss RR: yeah, same problem man...i think i need a new pressure plate and clutch disc thats the only thing i have old...ive already bled it and nothing still wont go into gear im ordering one today
