struggles and dies unless maf is unplugged
Old 08-24-2013, 07:01 PM
Tolley's94z28's Avatar
Default struggles and dies unless maf is unplugged
If the maf is plugged up the car will struggle at low idle for a bit then eventually die. If it is unplugged, the car runs fine.
Voltage is fine on yellow and red wires.
Where does the maf ground at?
Is it just time for a new one?
P.s. what are the two wires that go down the drivers side with the m6 harness?
One is black, the other Brown.
Old 08-24-2013, 10:23 PM
Camaro350Z28's Avatar
know anyone where u can just swap mafs and try? its probably bad
Old 08-25-2013, 09:47 AM
Hit em Up's Avatar
Had same problem yrs ago and it was a blown fuse,replaced fuse and maf sensor started working fine!This was on my impala Ss not sure if that makes a difference.
Old 08-25-2013, 12:01 PM
96LT1Z's Avatar
Clean the MAF.
Old 08-25-2013, 07:24 PM
Originally Posted by 96LT1Z
Clean the MAF.
I have. The screen has a few crushed spots, would that make it act up?
Old 08-25-2013, 09:07 PM
93Euphoria's Avatar
Yes it can!
Old 08-31-2013, 01:04 PM
96LT1Z's Avatar
Take the screen out, i dont have on in mine
Old 10-15-2013, 08:55 AM
Finally got around to trying out a maf that I know is working, and I'm having the same problem.
12± at the red wire
5± at the yellow wire
The ground is on the driver's side rear head, correct?
p.s. What is the dark brown wire that runs with the ground?
Quick Reply: struggles and dies unless maf is unplugged
