Stock lt1 injector replacement.
Long time reader first time poster.
Short question what are my best bet for replacing leaking injectors in my 97 camaro?
Gm?
Bosch?
Accel?
Trick flow?
Gm?
Bosch?
Accel?
Trick flow?
if you replace your injectors with anything other than exactly what stock 24 lb injectors are, you need to tune the PCM for them
you can have your injectors rebuilt for around $10+ each
www.cruzinperformance.com is who I have used before
Yeah I was planing on just getting 24# injectors just curious if the aftermarket ones are reliable?
I work at gm and the tech's are telling me buy gm but those are 100$ a Peice! Will look into some where Canadian to rebuild.
One or more is deffienatly wide open. When I prime the system the fuel pressure drops in milliseconds.
the link I posted I know ships anywhere. I know Canada can be a PIA for packages to/from the states but still doable.
or buy a used set in FS of this forum or others
Not that other brands are "bad". Just diffrent brands, especially if diffrent #rating, require adjusted tune in PCM to work right
