Rag Joint Part #
Rag Joint Part #
whats the part number for a stock replacement? Im not sure that I want to go with a solid or delete it due to the steering wheel vibrations. Reason im replacing mine is because there is about 10 degrees of play in the steering wheel. Let me know if a rag joint can help somewhat to steering wheel vibration as well.
^^^ what he said... Do a search & find out how to reclock it & your steering will go where ya point the MFer!!! Its easy & Way better than the rag joint BS... I liked the swap soo much in my T/A Im swappin a jeep set up into my S10 solid axle build Do it & youll thank us later LoL
Village Troll
Rag joint eliminator is also an option for those who want to spend $40...
http://www.unbalancedengineering.com/Camaro/
Hey Matt did the Lsx rack and sterring shaft bolt right up to the kmember, steering and ps hoses or did you have to modify anything? I already have the LSx sterring shaft so if no mods are needed I'll just buy an LSx rack and install it, thanks.
Do you gain any vibration with the solids?
I did this to a 2000 S10 i built.But I cut the reag joint off and used a U-joint.I thought about doing this to my 94 z28 and was affraid to do it.I would think you can use a U-joint on the Z28 mod.What do you all think.
Warriorcustoms,,you can cut the rag joint off your s10.And buy a u-joint froms joes welding and bolt it right up.Its a very simple mod to do.Ive had my s10 done 6 or 7 years now.Its a common s10 mod.
2X Vote
My stock unit appeared to be fine / tight / without issue before the upgrade as well, but (given the change) it must have been somewhat loose, even though I could not perceive any motion prior to the upgrade.
