LTCC conversion worth it?
Obviously it works pretty damn well but is it worth the price? It's $399 for the box and harness and another $750 for 8 coil packs! I'd love to do this but that's over $1200 for the conversion.
And Caprice, I've had my fair share of bad optis since mine isn't vented. The 95 z28 I used to own had a vented one and I never had an issue with it. That may be why yours is fine.
I put a new GM opti on my car 5 years ago for ***** and giggles and it hasn't missed a lick, the factory one was fine. 30K miles, 100+ track passes, driving in rain, etc etc all on a stock non-vented Opti. I don't understand the hate, I believe it's just user error.
I've had a few people tell me it's not worth the money but the ones who've told me that already have a vented opti. Mine does not so it goes bad much sooner. I'm probably going to go the MSD cap and rotor route for now and possibly the conversion later if the MSD doesn't work as well. Has anyone here made the conversion with a non vented opti?
The EFI 24x setup has made the LTCC setup obsolete.
It is a much more advanced package, with a lot more benefits then just ditching the opti - which isn't very problematic in its own right when using quality units and doing a proper installation.
Man-Crush Warning
If you can source coil packs, PCM, and a crank/cam sensor all you need is the reluctor and cam piece from EFI. Then of course you need to repin your harness.
I would say mine was under the cost of an LTCC but I got a PCM and coils for dirt cheap.
Someone correct me if I'm wrong, but doesn't the LTCC use standard LS-Series ignition coils? Our most expensive pair of coil bracket assemblies (coils, brackets, hardware, and pair of coil harnesses) is a few hundred dollars less.
LS1Tech Sponsor
I do not know where you are paying almost $800 for coils. Even coils alone without our brackets go for $250, $500 less than where you looked. Ours are alo 100% brand new.
Bill
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
That's MISTER MODERATOR
The LTCC system is supplied with coil plugs for LS1 & LS6 ignition coils. All other LS ignition coils have different keyed and pinned plugs.
So don't just buy coils-make sure they fit your LTCC-or EFI Connection kit if you wisely decide to go that way.
LS1Tech Sponsor
__________________
1-888-467-4491
1-888-467-4491
LS1Tech Sponsor
I would expededite getting them in if I knew they would sell.
Bill
__________________
1-888-467-4491
1-888-467-4491
