1 wire o2 sensor to heated o2s
Old 11-29-2013, 02:55 PM
saltwaterreefguy's Avatar
Default 1 wire o2 sensor to heated o2s
Anyone know where there is a kit available? I searched this the one guy that makes these is he still around?
Old 11-29-2013, 06:34 PM
9-Second Club
Ed Wright's Avatar
Nothing to it. Check with a parts store. Been a while, iirc the '92 and/or '93 4.3L V6 Chevy pick ups had a 3 wire heated O2 sensor. Terminals A,B and C. The center wire (B) was the signal wire, like the only wire on your old one. A, or C, is ground (don't remember which ) and the other is heater power. A shop manual for those trucks should tell you which. The power wire is, on the trucks using those sensors, connected to the fuel pump relay wire terminal that powers the fuel pump. Pretty simple deal. Works very well for TPI cars, and TBI trucks when headers are added. Harder to get the O2 hot enough with headers.
Hope this helps.
Old 11-29-2013, 07:56 PM
Thanks a lot Ed, great info as always.
Old 11-30-2013, 06:50 PM
duh
duh's Avatar
Look up Fastbird. IIRC that's the guy I bought them off of when I did my longtubes.
Old 12-02-2013, 11:48 PM
FrankieD's Avatar
here you go:
http://www.casperselectronics.com/st...roducts_id=698
Old 12-03-2013, 07:54 AM
93M6Formula's Avatar
Real easy to make your own harness. I talked to Fastbird about it. I bought new GM O2s for a '94 Fbody, two factory pigtails, a relay, and some wire and went to town. Works great.
Old 12-04-2013, 03:25 PM
Fastbird93's Avatar
Originally Posted by FrankieD
Good grief that's expensive.....You're looking at $185 plus shipping to convert the car. Just saying.....there's far cheaper options.
Old 12-04-2013, 04:48 PM
i'll be ordering the ones off your website as soon as my headers show up they should be here today. I want to tear it all down first and make sure nothing is missing. Thanks again.
I do have one question is this a must do when installing headers on a 93?
Old 12-04-2013, 05:36 PM
Fastbird93's Avatar
Depends. If you're running shorties you shouldn't need to make the change. SOME mid lengths will need the upgrade, and it's a definite if you're moving to long tubes.
When I bought the 93 T/A I still have, it was with stock O2's and had MAC headers. I swapped those for the Arizona Speed and Marine headers from my other 93 I had, and the car wouldn't stay in closed loop. Both are mid-length designs, but the ASM's moved the O2's enough to warrant the change, the MAC's didn't move them back from the motor much at all.
Old 12-05-2013, 08:49 AM
It definitely made a big difference in the way my car ran by switching to Heated O2s.
Old 12-05-2013, 12:55 PM
sweeet thanks now on the 3 wire o2s which is ground a or c?
Quick Reply: 1 wire o2 sensor to heated o2s
