question about transmissions
did they use different automatic transmissions in 93 and 95. am i gonna have trouble putting my tranny from my 93 in my 95.....maybe pcm trouble????
The '93 Auto is a 4L60 which is basically a 700R4. Non computer controlled.
'94+ is a 4L60E which is computer controlled. But they all don't interchange either due to electronic differences.
A few major differences
1. You'll need a 1993 throttle body to connect the t/v cable
2. Need to locate the wires from the brake switch for the tcc lock up.
3. May have to change the tail shaft housing and add a reluctor ring for the speedo to work, I'm not sure on this.
Other than that it should bolt right in.
Do research and you wont have any issues, they sell a vacuum kit for those trannys that does away with tv cable. tail shaft should be the same and uses the same cross member. they also sell a tcc lock up kit thats universal.
