Trouble starting
Trouble starting
Okay here has what happened:
-Bought 1994 Z28
-Put $20.00 of premium gas from Marathon
-2 days later car doesn't start, just cranks and cranks
-2 days after that car clicks, no cranking
-Have battery and alternator checked = all good
-Find out starter is bad, replace starter
-Now it cranks and cranks like before
-I recall SES light turned on right before car started to just crank and crank
-Try to check SES light with an OBD1 scanner and the light doesn't flash
-I have checked fuel pressure and it checks out good
Here is a video of what it currently sounds like currently:
I need your help! Any thoughts or ideas?
-Bought 1994 Z28
Good diagnostics. First, have the codes checked. Most parts stores scanners or the simple plug in ones do not work. The next thing is to couple what you learn from the code stored with Fox Slaughter ' link
I appreciate your link- was a big help. I am having a friend help me out this week with getting it to fire. So hopefully good news to come.
Thanks for the tip- ill let you guys know how it goes this week. Hopefully we get her to fire up!
Okay. Just for future reference, if they temp sensor in the waterpump goes bad, which is a common problem, that is a simple way to test it. Mine was bad, and would crank and crank and crank and not start until I held the gas to the floor
