Anyone know the part # or where I can get the speedi sleeve for my crankshaft hub?
Old 02-05-2014, 07:33 PM
whytryz28's Avatar
Default Anyone know the part # or where I can get the speedi sleeve for my crankshaft hub?
Found a few threads but nothing I found saying what size or part number sleeve for the lt1 crank hub.
Old 02-05-2014, 07:50 PM
guppymech's Avatar
I found these at O'Reilly's for your '93. Hopefully the link works, can't check it out I'm at work.
http://www.oreillyauto.com/site/c/se...aro&vi=1035852
Old 02-05-2014, 07:53 PM
whytryz28's Avatar
thanks, couple sizes listed though.
Old 02-05-2014, 07:57 PM
guppymech's Avatar
The two Nationals and the Master Pro are the same part numbers 88176, the National p/n 5000 includes a new seal. Rock Auto lists the same part numbers for your car. If you have a dial calliper you can measure your hub to double check.
Old 02-05-2014, 08:01 PM
whytryz28's Avatar
Thanks a ton guppy
Old 02-05-2014, 08:08 PM
guppymech's Avatar
whytryz28, You are most certainly welcome, I hope they work out for you.
Quick Reply: Anyone know the part # or where I can get the speedi sleeve for my crankshaft hub?
