Turbo Lt1 Spark plugs
Old 02-06-2014, 04:57 PM
LS1Tech Sponsor
saccitycorvette's Avatar
Default Turbo Lt1 Spark plugs
Hey everyone,
I have a 383 ,stock ported heads and intake, cc305, delteq coil system, and a rear mount t70 turbo. Im having a issue under boost, sometimes the car will cut out and backfire hard. Im thinking the spark is being blown out. Im currently running the ngk br7ef plug. The car will see 15psi. Any ideas on plug and gap I should try?
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 02-06-2014, 05:45 PM
Kevin Blown 95 TA's Avatar
For consistent spark, you might try a .03 gap.
What is the rest of your system like? Do you know for sure that you have enough fuel? Intercooled? Water/meth injection? Tuning or boost timing retard?
Old 02-06-2014, 06:05 PM
LS1Tech Sponsor
Hey Kevin,
I have twin in tank 255 pumps, 60 lbs injectors, big front mount intercooler. My AFR is on the rich side right now at 10.8 and I run a 2 bar sd tune on a stock pcm. I have 27 deg timing on low boost (8.5 psi) and 24 deg on high boost (15 psi). it will cut out and back fire on the low boost setting too. It will almost feel like I hit the breaks and a lot of fire and black soot comes out when this happens.
__________________
Old 02-07-2014, 08:00 AM
moehorsepower's Avatar
Originally Posted by saccitycorvette
Hey Kevin,
Your Plug range is good, Like said I would try 28-30 on the gap, 10.8 is too rich, need to lean it up a point. You running brave with that timing on the high boost.
Old 02-07-2014, 01:13 PM
LS1Tech Sponsor
OK That high boost timing is after the pcm adds it 4 deg. Ill try closing up the gap.
__________________
Old 02-07-2014, 01:20 PM
LS1Tech Sponsor
Do you think a tr6 plug would be better for my car being that its a daily driver
__________________
Old 02-07-2014, 02:39 PM
Maybe in the winter, I would keep it at 7's, I run 8's with 15lbs..
Old 02-07-2014, 03:24 PM
LS1Tech Sponsor
ok Ill try the tr6 gapped at .030 and just run low boost around 8-9psi
__________________
Old 02-07-2014, 03:26 PM
nitrous2fast's Avatar
I would keep closing the gap until the idle is affected, then add some just until it clears up. start with .026
Old 02-07-2014, 03:36 PM
LS1Tech Sponsor
Start with .026 and go smaller from there? Is that with the tr6 plug?
__________________
Old 02-07-2014, 04:07 PM
I wouldn't use the tr6. go with the br7's and start at .026. If it stumbles while idling at that gap start opening it up. If it doesn't, then lower the gap to .024.
Old 05-20-2022, 07:16 AM
sewerpickle's Avatar
Make sure it's not your wastegate opening prematurely. I've seen this happen multiple times.
Quick Reply: Turbo Lt1 Spark plugs
