turn signal help!
turn signal help!
Im having a problem with the right front turn signal not working. The left side works fine and when i do the hazzards all work but right front. It started working on and off and for the last two months nothing but a solid light on the dash and nothing on right front. Ive done a search and checked the ground, replaced the socket and buld now im out of ideas. Any help would be appreciated! Thanks
Sorry forgot to mention its a 93 camaro z28
EDIT: Whoops didn't read good enough that you checked the ground. That's the only issue I can think of. I would chase that ground to make sure it doesn't have a break in it.
