jegs sport stars?
jegs sport stars?
I have a 93 firebird and im looking into purchasing a wheel and tire package from jegs 15x4fronts and 15x8 rears is there gonna be any fitment issues?
Just run 5/16" spacers with conical shank lugs and you should be set. Make sure you get the proper backspace too..
The 15x4 are 1.75" backspacing
15x8 is 4.50" . Really dont want to run spacers unless i have to 😒. Ive.heard of.people grinding the.calipers some if i do that will i still need spacers?
You should have gotten 5.5" BS for the rear. Your going to need rear spacers now with the 4.5" BS you ordered..
Neworleanslt1 test fitted them they stuck out so far gonna call jegs and exchange them for the 5.5" backspacing. The rear tires i got are mickey thompson et street radial size 275/60r15 they almost look to big to fit in the rear fenderwall does anyone else run this.size.tire on a 93?
Basically just a weekend car to beat up on the young punks around my area.not sure on the rear gear size. Im just.wanting to no if they will fit in the wheel well?
I would still suggest the 275/50. The 275/60 is a 28" tire that balloons under acceleration. This will cause slight rubbing, usually around the back if the wheel well on the bumper cover. The 26" tire doesn't grow enough to cause problems and will give a bit better acceleration down the 1/4 mile. The 28" is good for bringing up the mph tho. I too thought about going to a 28" tire, but I don't feel like clearencing the body to keep my et the same with a bit more mph. I like my 12.9's at 103 before the gear swap. Once the snow melts I should be right around 12.7's at the same mph. Unless you want to put 4.11's in the rear I would stick to a 275/50.
