mechanical oil pressure gauge?
Can i remove my oil pressure sending unit to the stock gauge and tap my new line in there?
I have a 93 so im not sure on where else i could tap into?HELPPPP!
You can buy a fitting that screws into the motor, then have the stock sensor screw into the fitting, then have the aftermarket sensor T off and connect your gauge there.
Luckily I have a 95 and I can use the plug right above my oil filter to add a sensor since my stock one is on the top of the motor behind the intake manifold.
I have the proper fitting.butdo nothavethe t-fitting.but can i remove the oil pressute sending unit(just unscrew it from the block) and run my line there?
How are you guys feeding the lines into the passenger compartment?
I know about the grommet on passenger side where computer harness comes through the firewall. Is there a similar grommet on driver side?
I currently have a mechanical oil pressure gauge under the hood. It is connected with a 26" stainless braided brake hose that can be routed under the back of the hood and placed on the windshield when needed.
Question. Does anyone see any safety concern using this brake line for providing pressurized oil to the gauge? Is it likely to fail and spray oil and burn the car to the ground? Its been good for 3 years now but I am thinking of pulling it since it really is not being leveraged.
