Help with replacing exhaust manifold gasket
Old 03-23-2014, 01:55 PM
VergeltungswaffeZwei's Avatar
Default Help with replacing exhaust manifold gasket
Im in the middle of replacing the driver side exhaust manifold gasket and I can only pull back the header at least a 1/4" to a 1/2". Do I need to remove the steering knuckle to move it any farther to put in the new gasket? Headers are BBK. So far ive loosened the header at the y-pipe and the let me move it a little but not enough to where I can get in there and clean the mating surface.
Old 03-23-2014, 02:25 PM
leadfoot4's Avatar
You may have to disconnect the header from the y-pipe, and take the header out of the car...
Quick Reply: Help with replacing exhaust manifold gasket
