ABS, and TCS Reluctor rings HELP
Old 04-04-2014, 09:13 PM
96LT1Z's Avatar
Default ABS, and TCS Reluctor rings HELP
I know this is not the axle and gear section. But this is only for LT1 cars and there are not very many reluctor rings out there. Alright I have 1996 Z28 Camaro. It has ABS and Traction Control. I pulled the axles out and they are mix matched and they are not stock. I think one of them is causing a vibration that ruined my wheel bearing on the pass side. Heres the deal its a 4 channel and I NEED THE RELUCTOR RINGS, because they are not the right size. I have two different ones, which is making my abs and tcs freak out. I cant find them anywhere. I can find the center reluctor on the carrier. But I need the two small ones that go on the ends of the axles!! HELP I need a part # or something. HELP
Quick Reply: ABS, and TCS Reluctor rings HELP
