Zero Oil Pressure
Zero Oil Pressure
So I was driving today and noticed that my gauge read 0 oil pressure. I also have a pillar pod with another oil pressure gauge with the sensor in the auxillary port by the filter, zero there too. So I got the car home and restarted it sitting still to watch. I noticed very loud ticking. I don't think it's knocking but I'm not totally sure. Oil is full and none has sprayed everywhere under the car. Slightly rougher idle than normal. This also isn't the whole thing with braking and reading 0. It read 0 just sitting still as well. Car has a hotcam kit and boltons. Any ideas what's going on? Happy Easter to me!
Do you have a HV oil pump?
To change the gear, pull the intake, and unbolt the little thing running into the block.
Or pickup tube could of fallen off. Just tap on the pan and see if it has something in their making noise, or get a magnet and see if it catches it and pullss it around.
No I'm not driving the car around. I noticed it as I was turning into my neighborhood and let it coast home. Hasn't moved since. I'm not running the car. I don't have a check engine light or anything on either.
It won't set a check engine light for oil pressure. If it has killed the oil pump drive gear, you will want to pull the oil pan and clean it, and clean or replace the oil pump pickup. Always drops a nasty mess of metal shards in the sump.
OP -
Before you assume the lower metal gear is stripped, pull the intake and inspect the plastic upper mount - the drive might be broken at the plastic mount.
If this is the case, you may (remember I said "may") be able to remove the Oil Pump Drive from the top and replace it without pulling the oil pump. Having said that, both metal gears must be inspected for damage first.
FYI - I've replaced two; one because the actual metal drive gear was damaged, and a second because the plastic mount broke at the bolt hole. With the damaged gear, I pulled the cam and the oil pump; with the damaged plastic, I was able to replace it from the top without pulling the cam and pump - that was much easier.
Good luck!
Good luck!
Gonna be tearing into the car this weekend. Been doing some reading on these oil pump drive gears failing. Seems like a lot of horror stories. Am I likely to need a rebuild? Or can I just replace the gear and be good, once checking the oil pan of course? What should I look for?
You SHOULD pull the pan off and check the bearings and stuff. Or if the car wasn't driven but a SMALL distance once it hit 0, you can gamble like me and replace it and keep going.
Well I got a head start and pulled the gear out tonight. Few of the gears were stripped bad. So where do I go now? Should I replace the whole oil pump with the new drive gear? Also where should I get a new drive gear, just autozone or wherever? I'll be pulling the pan off tomorrow night to get the metal out. How do I know if my bearings are good or bad?
I think you're correct but in my case the gears were definitely stripped. I took the drive gear out and like 4-5 teeth were almost flat. Also to update a little. I checked the cam with a mirror and it looks good. The oil pump itself also turns freely still so that's another positive.
That was my gear. Those edges are super sharp instead of flat like they should be, it's like that half of the way, the rest it is smooth. idk why it didnt go out sooner.
This is the gear I got - Replacement Distributor Gear 19052845 This
If you have a HV pump, like I do, it was recommended to go back to stock.
On the rod bearings, I was told to check for "Scars" or grooves on them, they can take out rods and stuff if their bad.
Village Troll
http://www.summitracing.com/parts/ar...make/chevrolet
