95 z28 m6 gear swap from 273 to 373
Old 04-25-2014, 09:40 AM
hockeyguy039's Avatar
Default 95 z28 m6 gear swap from 273 to 373
Hello I am going to do a gear swap for on my 1995 camaro from 273 to 373 I am just wanting to know what's the best brand to get and also what website to order from i will also need a install kit and just need help figuring out where to order from summit , jegs ...etc
Old 04-25-2014, 09:45 AM
Village Troll
SS RRR's Avatar
GM Motives have the best reputation. If you are going to do this yourself then check out the sponsors to see if they have anything you can use. If you are going to have a shop do it, by all means, let them order the gears and rebuild kit. That way if something goes wrong they cannot simply say "well it's the gears you ordered and you're screwed..."
Old 04-25-2014, 09:58 AM
I'm having a shop do it but it's a friend of mine and he wants me to order all of the parts
Old 04-25-2014, 10:10 AM
TravisMcGill2000's Avatar
Dont forget you will have to have a retune. That big of a gear change. Will throw off your wot shift points. If I was you I would try find complete rear out of a 6 speed car. Its 3.42 gear and Is a great all round gear. Plus there factory gears and stronger. You van usally pick em up for round $250.
Old 04-25-2014, 10:57 AM
Village Troll
SS RRR's Avatar
Reuse used unknown used gears? Too much of a crap shoot IMO.
Old 04-25-2014, 11:31 AM
nitrous2fast's Avatar
I didn't know that 95 M6 cars had 2.73's?!?! or am I just dumb...
Old 04-25-2014, 11:39 AM
Catmaigne's Avatar
Nope, but I drove my car around for about a year on 2.73 gears and M6. It was absolute hell going up hills.
Old 04-25-2014, 01:01 PM
Hey im having good luck with them. You can find good stock rears. Ive broke 3.73 and 4.10s. Never broke a stock 3.42 gear so far. Of course im a auto tho.
Old 04-25-2014, 01:03 PM
Were does it says his is a m6. I assumed a4 since 2.73.
Old 04-25-2014, 01:17 PM
ditchdrift's Avatar
in the title of the tread....
Old 04-25-2014, 01:35 PM
Well **** im blind. Lmao nevermind bout the shiftpoints and 3.42 then.
Old 04-25-2014, 02:10 PM
93M6Formula's Avatar
4.10s are way better with the 94+ 6-speed cars. Don't bother with 3.73s.
Remember you have double overdrive. I'm still under 2K RPM at highway speeds.
Old 04-26-2014, 10:51 AM
Thanks for all the replies and the reason it has 273 is it was converted from a auto to m6 ....but I still don't know where to order my gears from
Old 04-26-2014, 02:43 PM
Catmaigne's Avatar
I went with motives 4.10s from jegs and they were fine until I started beating on them.
Old 04-26-2014, 03:02 PM
Spartan7's Avatar
I've got 3.73's with an M6, also a conversion car. Parking lots suck at lower speeds, but I like them. They are completely silent, and I'm not exactly nice to them. I went with Motive gears and a Ratech full rebuild kit, both from Summit. Just make sure when you get your rebuild kit that you've got some good USA or Japan-made bearings, not cheap Chinese crap.
Old 04-26-2014, 03:37 PM
Okay thank you spartan7 that the kind of answer I was looking for
Old 04-26-2014, 07:21 PM
Big Al's Avatar
I'm with the guy that said get a complete rear axle, disk to disk out of a 6 speed car. Just remember we said that... You'll be way ahead...
Al
Old 04-26-2014, 07:24 PM
F0x Slaughter's Avatar
I am running 4.10s at 70mph I am under 2k.
Quick Reply: 95 z28 m6 gear swap from 273 to 373
