What type injector for LT1? High or low impedance
Hey guys,
Just buying new #42 injectors for my 383 and I'm not sure if I need to buy high or low impedance? Did a search and didnt see anything. Also, what type of connection is required or is it standard? Thanks
OP
check with your tuner on what specific brand to get. Some prefer some brands over others. more because they are familiar with their specific characteristics (pulse width, etc), especially if getting a mail order tune
Gotcha...probably go 36 then just to leave myself some room....want to run a wet n2o set up so I assume I need a larger injector??? (I may be misinformed or lack some specific knowledge there)
So, 30's will still do. If you still want to go with 36's, no argument here, they'll be fine too.
What you do need for nitrous, wet or dry, is for the rest of the fuel system to be up to the task. I'd run a GENUINE Walbro 255 lph in-tank replacement and upgraded wiring to provide full alternator voltage to the pump. That would take care of 450 rwhp plus a 100 shot, maybe a 150.
