Oil cooler delete walk through?
I've spent some time searching, here and via Google, for a detailed walk through on deleting the factory oil cooler/warmer... Anyone have a link to such info? I'm looking for step by step, with a list of all parts needed... Pictures would be a bonus.
For reference, I have a '95 with the later oil cooler (silver/aluminum, vertical mounted coolant inlet/outlet lines)
Thanks for the pictures!
Is the process the same for the '93-early-'95 cooler and late-'95 style cooler?
Do you have to drain the whole cooling system, or just the radiator for this?
You're definitely going to have to drain the radiator and you will more than likely lose a lot of coolant from the engine once you disconnect the hoses.
