What static timing for LT1 with HEI
I'm putting an LT1 into a 4x4, its running a carb intake with my existing TBI throttle body and an HEI distributor, I've got a keyed damper and timing pointer on the front of the engine, do I static time it at around 8-10 degrees like a gen 1 engine or do LT1's use a bit more advance with the reverse cooling? thanks for any info.
