Whistling LT1
Old 05-15-2014, 08:56 PM
The Outlaw Kid's Avatar
Default Whistling LT1
I just got my car back together and there may be a problem. It seems to whistle at idle only.
I swapped in pacesetter long tubes, pacesetter ORY, mangaflow catback, a new opti, plugs,wires, deleted all the emissions stuff, and pulled the intake.
Well the exhaust was the last thing I did so I was able to let it run on open headers. I didn't hear it whistle while on open headers.
After the rest of the exhaust was done. I was able to see/hear it run more. The idle stays steady at 1000 RPMs for about 5 minutes, then drops down to about 700-800 RPMs and stays steady. While it idles it's whistling, but when it's under load it doesn't whistle at all. I retightened my header bolts and it seemed to stop but it came back.
The whistling can be heard inside or outside, hood open or closed.
BTW, I used remflex gaskets so I know it can't be those crappy paper gaskets pacesetter gives you.
Here's the video.
Old 05-15-2014, 09:07 PM
cardo0's Avatar
I would guess a bad header flange surface - not uncommon. U would need to take the header off again and have it resurfaced - or send it back.
Good luck,
cardo
Old 05-15-2014, 09:09 PM
Good luck,
cardo
Good lord I pray that's not it. But I hadn't thought of that. Is there a way to check it while it's on the car?
Old 05-16-2014, 12:04 AM
Village Troll
SS RRR's Avatar
Aftermarket throttlebody?
Old 05-16-2014, 06:42 AM
No just the stocker.
Old 05-16-2014, 06:52 AM
93M6Formula's Avatar
An exhaust leak doesn't make a whistle sound in my experience. Usually sounds like a puff of air or a ticking sound. Have you checked vaccuum lines for leaks or anything?
Old 05-16-2014, 07:09 AM
Just visually nothing appeared worn or loose. I'm gonna hit the parts store when they open for a vacuum gauge.
Old 05-16-2014, 07:27 AM
I swapped in aftermarket valve covers. The driver side had a spot for a breather. So I put a baffled grommet and a breather in it, you think that would cause it?
Old 05-16-2014, 08:25 AM
Man-Crush Warning
Shownomercy's Avatar
Do you have a CAI without a AIR pipe attached?
Old 05-16-2014, 09:12 AM
Ram air with the AIR fitting capped off.
Old 05-16-2014, 09:37 AM
hrcslam's Avatar
Can you post a video?
Old 05-16-2014, 10:08 AM
If someone can give me a quick run down of how to post a video.
I got a vacuum gauge hooked up. It idles about 19 in Hg. Hold it at 2000 RPM it sits steady at about 22.5 in Hg. Snap the throttle it jumps 25-26 in Hg. Then goes down to the 19 in Hg again. To me this doesn't seem right, after I snap the throttle it should drop right back to 19 in Hg. It doesn't sound like the vacuum leak hissing you would normally hear, like when you pull a line off. It sounds like a dead on whistle.
Old 05-16-2014, 11:37 AM
Video added to the first post.
Old 05-18-2014, 10:11 AM
I wound up pulling the belt and the noise stopes. I've never heard an accessory or belt make a noise like that. I think it's either the belt it's self or the alternator fan. One of the fan blades has a crack in it that's why I'm leaning towards the fan.
Quick Reply: Whistling LT1
