OD or D for 1/4mile racing??
When you guys are at the drag strip are you running in Drive or OverDrive for best times/results?
Unless your valvebody is setup to provide more fluid volume (less restriction) during the application of the 3-4 clutches, shift quality and 3-4 clutch life is best by running in "OD". Running in "D" robs pressure from 3-4 clutch application during that critical split second of the 2-3 shift.
In a really high powered application, I agree with Jeremy's point; just make sure you have the valvebody mods to do it.
I've not hurt the sprag in mine by running in OD, racing it for 4 seasons with 500+ hp.
I have a 4L60e and I noticed that my car bounces off the rev limiter once or twice during the 2-3 shift when running wot in D. I had shift points lowered with no luck. I thought the tranny was on its way out. Then I made a test hit on the street in OD and it shifted fine. I just never understood why..
Also, if your shifts occur really close to the limiter, you may find it hits the limiter when cold but not when hot. I'll sometimes hit it on the 1-2 shift 1st pass at the track, but not thereafter. The higher viscosity of the colder fluid slows the shift down by a few mSec.
Wow this good tread. I had it backwards, I thought your over-run clutch was applied when in D. I've always run D at the track. Never had any issues but tomorrow I will make a run in OD and see how it is. My friend who builds trans and races runs his in D, ( non Electric 700r4) Thanks guys.
Look at bowtienut's first post in this thread.
Maybe in a perfect world you would launch in a lower selected gear and then get the selector into OD before the 2-3 shift but that opens up a lot of human error possibility.
I think the overrun clutches are applied if you select a lower than OD gear manually BUT the 3/4 clutches get more pressure at the 2-3 shift if the selector is in OD.
If I'm not mistaken I think if you have the selector in 2nd at the starting line it will take off in 2nd and not 1st.. Your car will launch like a turd..
In 4th lockedup would only ever come into play in atop speed or salt flats car geared to use all available engine rpm and I don't think anyone would do it that way they would use numerically low gears and just keep it in the more efficient 1:1 third gear.
Maybe a standing mile car would use 4th locked since they need acceleration of deeper gears and still top speed
