Vacuum leak
Vacuum leak
I'm having a vacuum leak and idk where to start to find it. It's a 1995 3.4 v6 and the diaphragm for it is to confusing so actual photos of it would help a lot more.
Grab some carb or brake cleaner, start the car and start methodically spraying area's of the engine until it sputters. Then pin point the vacuum lines and connections in the area until you find the actual leak. Repair and replace as necessary.
Keep the spray away from the exhaust manifolds!
