Ugh, another one of THESE threads
I Bought a 95 camaro today and since im basically useless when it comes to diff's because I'm only 16 and never cared about drivetrain apart from trannys.
I looked under it and there was grease on the end of the driveshaft going into the diff and its flung all over and is runny in spots. I'm assuming its a seal or something but as I said I'm diff and driveshaft illetrate.
It also doesn't like to start first crank unless I turn the key on and off to prime the fuel pump. Assuming its A fuel pump or valve but hopefully someone can clear it up for me.
It hesitates for a split second if I give it too much gas too quick. Hoping a sensor needs cleaned or something, other suggestions?
I have yet to change any fluids, plugs or filters so hoping all that will eliminate some of this.
Its the lt1, it smells a little like gas from time to time but I marked that off as just The exhaust but I could be wrong. The fuel pump also whines A little which isnt really noticable unless you listen for it.
