Balancer problem
Balancer problem
Cars together (finally) and running great.
(Eagle 383 fully built and tuned) 24X conversion
anyway, 2 times now the damn crank pully bolt has backed out and the harmonic balacer has fallen out/off...
Please advise...
Please advise...
Thinking this will fix it, amiright?
http://www.jegs.com/i/JEGS/555/51609...FZBxOgodljEACg
http://www.jegs.com/i/Professional+P...80030/10002/-1
http://www.jegs.com/i/ARP/070/134-2503/10002/-1
OP
you say "balancer fell off"...when you install it do you have to use a "pull tool" or does it just "slide" on the crank?
you should not have to use loc-tite...something is wrong if bolt keeps coming out and damper/hub come off.
Is this a manual trans car? I worked on an old school SBC that had the same problem, it ended up being a bent input shaft on the trans, he couldn't keep a balancer on it for more than a few minutes.
