My Discount opti experience
Recently got "error 36 code, high resolution failure"
So purchased a new Delphi Opti , and had it installed.
The old $150 Chandler opti, with 4000 miles, failed, and upon inspection, just tells me "You get what you pay for".
Chandler opti I locke-tite the rotor screws, and RTVed the outer case.
Pics show no, oil leaks, no water leaks, the optical sensor in tact and the optical ring not bent or any damage, rust ,or oil.
The Cap shows minimal wear , but the rotor shows contact wear only on one side.
Looking closely the rotor where it contacts the outer cap, is bent!
Others may have been luckier with chandlers, but my new Delphi powered bitch car runs better than ever.
Good luck out there!!!
Village Troll
Before installing the chandler, did you spin it to see if it made any scraping noises? I once ordered an opti from Autozone a few years ago, don't know what brand it was, but spun the rotor and it scraped the entire revolution. I told them no thanks.
What ever happened to The Parts Ladi? Didn't she have a good rep at some point in time?
I replaced cap and rotor with an msd and kept the stock opti. My rotor hit the back side of the opti when I was reinstalling. two thin washers spaced it enough to clear. 10k later still no issues, not sure if this would have been the issue with the one you got had you opened it up.
My chandler failed about 20k miles after install, but they were fast with their return/replacement and now my cars back up and running. Hopefully the new one isn't a dud, but lifetime warranty is hard to beat.
FWIW I bought a Delphi from thepartslady YEARS ago. IIRC it was like $1xx. It came in a Delphi box. I have opened it, loc-tite the rotor screws and have used it on a few builds. No problems.
It does have a Mitsubishi optical sensor
yeah the offshore clones sold by most auto part store chains do come with a "lifetime" warranty...but given the PIA job to install a Opti, IMHO get a Delphi or if you can find a "new" AC Delco
If you have a old AC Delco that works, get a MSD cap/rotor kit. Confirm the bearing is still in good shape
I had a Summit opti fail on me after about 10,000mi. I replaced it with a cheap Chandler opti and put a heavy duty cap and rotor on it.. I put Loctite on the rotor screws and RTV the cap and everything is fine so far..
thats better than my chandler experience. the center section was clocked wrong when they pressed it together. I didnt notice, put it on and the car wouldnt even try to fire. Spent the day checking fp, ip, spark, and compression. finally pulled opti. it was in correctly, but when i checked rotor position compared to my old accel it was way off. the pic is chandler on left, accel on right, both with dowel pin slot on the back pointed at #6
