What's up the expensive intake gasket???
http://shop.advanceautoparts.com/p/f...anifold+gasket
Um what? $27
Of course I am going to get:
Now that I have seen there is such an option the questions must be asked.
Why? What is the difference? Has this ever even been a problem for LT1s???
I've never had an intake manifold issue but I'll be in there next week to replace the lifters and saw that there is a second Felpro option now and I'm scratching my head as to why.
Um what? $27
A handful of us have had the Felpro gaskets that are paper with the silicon bead around the ports fail and start sucking the bead into the port. I like the OEM style plastic gaskets better. I have used the gray rubber and metal Felpro gaskets from that cheaper kit too and they are fine.
I have always used the FelPro 1284's, no problems.
other selections & $
http://www.summitracing.com/search/m...nifold-gaskets
use acetone to clean off all mating surfaces before install. few choices on RTV, I use Permatex Black "ultra"
