Opti Spark Choices
Opti Spark Choices
Need to pick up an Optispark for a 94 Camaro. Got two bad out of the box cardone autozone ones (indexed wrong on the last one). Was about to order a Delphi but it seems like they aren't built anymore with the Mitsu sensor. Is there any source of ones with the correct sensor. I know this is a hot topic with buy "OEM" but it doesn't seem like that is an option anymore. Otherwise it seems my options are down to Petris vented or just get the Delphi. Thoughts? Links? Comments?
Thanks!
Thanks!
LS1Tech Sponsor
The MSD Pro Billet is a great unit but for the more budget friendly we sell the procomp units and people are having great luck. whatever you get dont forget the lock tight the rotor screws.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
That's great for them, no complaints for MSD here. I got mine for cheap to, girlfriends dad owns a partstore.
is this why you believe the Mitsubishi sensor is no longer used?
from an ad on amazon.com:
Note: Delphi partners with other manufacturers to supply the parts your car was originally built with. This product is in a Delphi package, however the part may have been manufactured by an independent Delphi supplier
Just wanted to follow up on the thread.
I'm not sure exactly where but I started to get the impression that Mitsu stopped making the sensor and Delphi started to use a different facility. It may or may not be true.
I ended up buying a msd through amazon for the simplicity of things if there was a problem. Amazon is great and friends have had good luck with MSD customer service. Now to the fun stuff.
Next day shipped the MSD and my friend and partner in crime who is a diesel mechanic during the day and has extensive experience in most things automotive installed the Opti while I was at work. Gets it in and it seems we have the opposite problem. Idles good but under load instant spark knock...and baaaaddddd spark knock. He takes it out and installs it 4 times and has another friend install it once just for good measure. All the same results.
So once I get home I flash the computer with 7 degrees of timing pulled out of the tables and its better but still not right. Why 7 degrees? This is what the MSD Opti can retard/advance with the adjustment screw thinking it was set all the way advanced. Well we pull the Opti one more time and I check out stuff for myself. Everything seems fine. We turn the adjustment screw and it is set the correct 1.5 turns. I install the Opti myself with what seems like the same results in fitment. We fire it up and voila.....fixed. Running good for a week now. What the problem was with the msd who knows. I'm wondering if moving the adjustment screw "fixed" something internally. Time will tell.
Timing screw was never touched ahead of time and was verified in the correct position which we put it back to. Odd thing was the autozone opti seemed 20 degrees or so retarded. The MSD seemed 20 degrees advanced or so. I'm wondering if the inside spline is "loose" and makes it easy to install one tooth off either way. Thats what it really seems like.
