Comp Cam XFI 268
Comp Cam XFI 268
Anybody using this cam in their car? if so how do you like it? i think i am going with this cam in my car trying to get some feedback on it..
Looks similar to the Hotcam, a little more lift and LSA and likely better ramps. But should drive very similar.
I have experience with neither, but those with a Hotcam can chime in or you can google that one too.
This one is better than the Hotcam if for the lobe profiles alone.
I have one in my 383. Very tame cam with a slight idle "note". Makes great TQ
I live in California so smog is a reality. Passes with no problems
If you are looking for a poser cam with a choppy idle/sound, this is not the cam
If you want great drivability, TQ and good HP throughout the RPM range, it is good.
Are there other cams that make more power, yes.
I am looking for a cam for a stock bottom end with AFR 195 heads, with a 3200 stall, LT's with a CAI, Flowmaster catback and 323's in the rear. The heads are not ported or anything this car is mostly going to be street driven with a trip or two at the track. So i thought this cam would work well for me.
I'd run the Comp Cam 503 with those 195 AFR heads
