Quench question
Quench question
Trying to learn all of the things I need to know (and do) when putting my engine back together after rebuild. I have been reading and see that optimal quench (after gasket) is the in mid .030" and that stock was .067-.069". Mine look to be in the hole .15-.20. Does that look right? You can see the oil residue on the cylinder walls where the piston stopped travel.
IIRC stock CH pistons are 1.55, so 3.48/2 = 1.74 + 5.7 + 1.55 = 8.99. 9.025 - 8.99 = .035 in the hole stock. So with a .051 gasket, you're at .086 stock quench (Impalla SS is .063). .035 quench is about the tightest I'd go (.040 if you're running a decent size N2O shot).
I'm actually rebuilding it and doing forged rods and pistons. I was just curious why my stock pistons sat down in the hole lower than what I had read. Basically about 1/8".
Ok thanks for the info, I thought that we had 1 and 6 completely at the top of the stroke when these pictures were taken. Just looking for info since I didn't know for sure. The car was supercharged, so I didn't know if when they had it torn down they changed compression. Thanks again!
I calculated my quench based on my stroke, connecting rod length, and piston compression height difference from the deck height (like the formula above) plus had gasket difference. But, mine was easy I had my block zero decked. Then I got a .045" head gasket (was shooting for .035" but ordered the wrong gasket).
I verified the quench during PTV clearance checks (the same way I did the PTV checks) and found the actual quench to be .043" So either the gasket compressed more than rated or the pistons are out of the hole a little bit.
This is all to say, the stock deck height on an LT1 is 9.025" (supposedly anyway, this can actually change from block to block slightly and even from the front of the block to the back -have the engine decked!). So if you get 1.560" Compression height pistons, 3.48" stroke, and 5.7" rods you'll be "in the hole" .025 inches, theoretically. But this can be measure with depth gauges and compressed head gasket thickness, or the same way you do a PTV check (clay or playdough).
That could be done with 6" rods and 1.125" compression height pistons. It'd give a HUGE quench of .160", detonation wouldn't be an issue though. And it would love boost. Although efficiency would be out the window.
We pulled the engine apart so I can't check anything now. I was positive the pictures I had were at TDC for 1 and 6, thats the only reason I asked. We had been comparing TDC with cam dowel position and I thought we left it there. I was obviously wrong. Just wondered if they did something to it since it had a T-Trim SC and it was stamped "race" on ID plate. Thanks again, just trying to learn this stuff.
This is my first rebuild, so thanks for the advice. Getting a lot of good info here! Already have the pistons, rods and crank out so I'll know what I need to do for the build.
