Switching back to oem pump
Old 08-20-2014, 07:57 PM
Camaro_ZL2's Avatar
Default Switching back to oem pump
Just a quick question i had a electric water pump installed about 2 years ago .now its failed so i bought an oem , what would i have to do to switch it back to oem or is it as easy as just bolting the new one in its place
Old 08-20-2014, 08:22 PM
myltwon's Avatar
Just undo whatever wiring you did, unplug whatever you put on the timing cover, and reinstall the splined shaft. Might be more I'm forgetting.
Old 08-21-2014, 05:12 AM
lt1-xjs's Avatar
I'd send it back to the mfg for repair. Installing the oem could be as easy as bolting a new one on, as long as the drive gear wasn't removed.
Old 08-21-2014, 08:50 AM
ahritchie's Avatar
Just curious, what brand did you have that died?
Old 09-16-2014, 07:26 PM
Camaro_ZL2's Avatar
csr they removed the drive gear so i have to stick with electric
Old 09-16-2014, 11:28 PM
Moderator
BizZzatch350's Avatar
Chances are since it's a 383 they used a double roller timing set.
Old 09-17-2014, 11:09 AM
BALLSS's Avatar
I would/do use the Meziere. 16 years no problem
Quick Reply: Switching back to oem pump
