solid roller cam help please
Ahh, tracking. Still not a small cam, but not huge either; but on the bigger side of things. Got it, thanks!
If all the parts come together then yes if it makes power past the 7200 mark then it is too much for the stock pcm. But you never know, I have had combos such as yours and for what ever reason,(Probably bad head porting) power fell off at like 6600 when in reality it should of peaked somewhat like yours. Had an Lt the other day, Cam in the 26x range, sheet metal intake, which looked like a modified Hogan intake for two dominators, and it peaked at like 6200, the owner was disappointed and it barely made 430 RWHP on a Mustang Dyno..
i took your post as you were saying i was some dumb kid, and trying to make fun of me. i dont know that muck about solid cams or stroker motors. i have only done 350ci with cam and some nitrous. i apparently took your post in the wrong way so i am sorry i called you a jackass. i know there are alot of guys on here with lots of knowledge and thats why i am asing questions. no i am not building this motor, someone else is but i still want to learn. so like i said i am sorry for saying your a jackass.
