Removing Pushrod From Clutch Master Cyl.
The firewall is in the wrong place using a Camaro master cyl .
Car is a '94 Caprice 9C1 LT1 and 6sp out of 97 Z28. Homemade
bracket between firewall and Camaro pedal bracket. Brake pedal
is positioned right, clutch pedal is 1.25" low and clutch releases at the floor board. So making the rod adjustable and avoiding threading the hollow
part. I'll weld a solid piece to the eye or just make a new piece altogether.
Quote: Lower one comes out not sure about the upper
Upper rod at the clutch pedal just unclips and slides off.
Lower just pulls out?
