lt1 Carb build
Old 09-16-2014, 10:55 AM
whojohnjones's Avatar
Default lt1 Carb build
I'm in need of a few answers with my Carb lt1 build...
Where do everyone route their steam vent line on a Carb build?
What is the ideal size Carb for a stock lt1?
Will 1.6 roller rockers help performance any? And will they fit under stock valve covers?
Old 09-16-2014, 11:07 AM
BALLSS's Avatar
I ran my steam pipe to the reservoir.
I use a 650
Crane Gold "narrow body" 1:6 RR fit under stock covers. Trimming the baffles though is simple to run any other brand
Old 09-16-2014, 12:26 PM
benny92's Avatar
Do you run a pressurized resevoir? Otherwise wouldn't that act like a constant leak, draining the cooling system into the resevoir until it overflows. The steam line should go straight to the radiator, or could tee into a line post thermostat.
Old 09-16-2014, 02:46 PM
fleetmgr's Avatar
A bone stock LT1 wouldn't need more than a 600 cfm carb.
Old 09-16-2014, 03:58 PM
Anybody have a link with a tee that would work...I have a extra port on my radiator but it's way too big it's for the heater hose return line...car is 85 cutlass
Old 09-16-2014, 04:52 PM
96capricemgr's Avatar
Why screwup a perfectly good LT1 by putting a carb on it?
If wanting a carbed SBC why go with an LT1 and the lone intake choice and likely tuning hassles of getting a carbed setup to not detonate with the LT1 compression?
Flip the LT1 and buy a cheaper smallblock with greater aftermarket support.
Old 09-17-2014, 11:15 AM
BALLSS's Avatar
Originally Posted by benny92
Do you run a pressurized resevoir? t.
I used a radiator & reservoir I had from a B-body for the transplant into a 70 Nova. I had a LT1 motor which is why I used it, just converted it to carb
Quick Reply: lt1 Carb build
