strange noise all of sudden
Its telling u it doesnt want anything to do with an LSX motor swap. Its crying for a BB chevy, something like a 496" stroker. Just bolts into a Nova with parts right off the shelf.
Wish i could put a BB in my 4th gen camaro.
And just curious on your opinions, if this were any of you, and you just exhausted most of your funds getting this 355 going, and this happens, how would you go about the situation? What's your gameplan? Its my brothers car, not my nova, and I'm just sick and tired of dealing with this ******* car and its constant letdowns. W.W.ls1tech.D.
If all is OK under the rockers, I'd look in the flywheel area. Pull whatever access covers are down there, and if nothing looks amiss, try to get a friend who can turn the engine over with a ratchet and socket on the crank bolt, while you look for loose s**t.....
I'd pull the rocker covers first, and look for anything loose. By any chance did you use the OE rockers? Maybe one of them spit the needle bearings out. If so, the Comp Cams trunnion kit will get you going.
Village Troll
With as deep as it is, I really don't think it's valvetrain related. It's also very fast which points to bottom end rotating assy. Only option is to either do like shoebox said and check to see if everything trans-to-engine related is tight, and if that checks out, start taking the engine apart and see what you can see.
Sorry to read the news. FWIW i brazed my tube on the pump last time i did one - mostly because i didnt have a weld machine. But u can braze all around the joint/tube if u want. Brazing still takes a lot of heat though and u will need to check your clearances (pickup and pump lid) after brazing.
Thanks for the follow up. Cool nova and hope to get it going again.
