MLS head gasket questions
Old 12-01-2014, 03:40 PM
waltsfastz's Avatar
Default MLS head gasket questions
As far as I see Cometic is the only company that makes a LT1 specific MLS head gasket. However there are other companys that make MLS gaskets much cheaper. Will a SBC head gasket work? If not what is the diffrance?
Old 12-01-2014, 04:24 PM
LivernoisMotorsports's Avatar
I'm pretty sure the LT1's are reverse cool. Different cooling passages. What do you need a MLS for? What are you doing with this combo?
Old 12-01-2014, 04:31 PM
93M6Formula's Avatar
What do you mean? Felpro, Victor Reinz, and Mr. Gasket makes LT1 head gaskets too. And yes, there are certain coolant passages that differ from a GEN I SBC.
EDIT, nevermind I see you mentioned MLS.
Old 12-01-2014, 11:30 PM
Village Troll
SS RRR's Avatar
Coolant passages. As stated, what's it for?
Old 12-02-2014, 06:20 AM
Man-Crush Warning
Shownomercy's Avatar
http://www.summitracing.com/search/p...-based-engines
Quite a few options. I run the TFS ones.
Old 12-02-2014, 11:19 AM
waltsfastz's Avatar
I guess I need to look at summits website more, I was looking in the book and didnt see those others, Thanks Ill probably go with the trick flows as well.
Old 12-02-2014, 11:24 AM
waltsfastz's Avatar
12.5:1 on a fogger setup. Not sure how long a standard gasket would last and Never had a lot of luck out of copper without o-ringing the block/head.
Quick Reply: MLS head gasket questions
