:urgent: Lost keys, help!
Hey guys lost the keys to my 95 Z28, it was a chipped key but I disabled the VATS system on it, what am I going to have to do in order to have some keys? Now as of right now I'm not certain there gone forever but, if they are am I fucked? I hope not please respond fast this is urgent! :/
Okay, the drivers door was swapped out by previous owner cause it was dinged up pretty bad by someone in a minor bump up, however the passengers side is still the same. Does that count?
That's MISTER MODERATOR
You can get a set of keys, ignition & doors from a GM dealership BUT it won't unlock the driver's door.
While you're there, you can have the dealership provide you with a door cylinder that'll match the vehicle keys. But you'll need to swap the door cylinders yourself.
OK, so when they installed the door they didn't bother to swap cylinders.
