Suggested parts for LSA Cam
Does anyone have recommended 1.6 roller rockers, pushrods, studs, lifters, timing chain, injectors,and head gaskets for a 227/235 .565/.571 110 LSA Cam from Lloyd alongside his LE1 heads?
I have a somewhat similar heads/cam setup that I've had for about 7 or 8 years now. I run GM LS7 lifters, Comp Cams Pro-Mag Non Self-Aligning 1.6 RR's, Trickflow 7.100" hardened pushrods, 30# Ford SVO injectors (red tops), ARP studs, Victor Reinz .026" head gaskets, and a new stock timing chain. I don't recall what guideplates I have, maybe Trickflow.
A lot of guys also use the stock GM Impala SS .028" head gaskets. I would highly recommend Non Self-Aligning RR's instead of Self-Aligning. You will want to measure for the correct pushrod length. Might want to also think about upgrading the fuel pump, a lot of us heads/cam run the Racetronix 255 pump.
I'm sorry I don't recall or have any part#'s handy but I hope that helps a little.
