traction axle on Non tcs rear end
I have a 95 firebird. I ordered axles from summit and it turns out the guy selected traction control axles. my car is not traction control. Will these still work .?
I don't see why they wouldn't. The only difference is that they'll have the reluctor wheels directly behind the wheel studs. If summit wont fix their mistake and send you the right axles for free you should take off the reluctor wheels. They are just pressed on. That way if you happen to break a wheel stud you can just knock it out the back and pull a new one in. If you leave the reluctors on and break a stud you'll have to pull the axles out, then press off the reluctors just to get a new stud installed. I had to do it before. It sucks having tcs.
