If you haven't done this upgrade to your LT1 F-Body, you should (LS1 front brakes)
I did the LS1 front brake conversion a few months back and wanted to share my experience. For the money and time needed to complete the swap, it is a steal. We all know how inadequate the stock LT1 brakes are, I have zero confidence in them especially when braking from high rates of speed. With most of us making our cars faster than stock, do yourself a favor and put the proper brakes on the car. I don't know why it took me 8 years to upgrade the brakes, probably because it's more boring than adding power or this or that but I should have done this a long time ago.
Benefits I realized after the conversion:
1. Drastically improved braking. Car stops very hard instead of pushing through the brakes like before. Much safer.
2. Weight. I put everything on a scale, the LS1 equipment weighs less than the LT1 equipment, resulting in ~10lbs. shed from the front of the car.
3. Aesthetics. The larger LS1 rotors and calipers look light years better than the puny LT1 setup IMO.
What I bought:
1. LS1 front brake calipers - $76 used
2. LS1 front spindles - $70 used
3. Stoptech rotors - $100 new/pair
4. Stoptech Street Performance Pads - $60 new
5. Bolts that connect calipers to spindles - $25 new (Unfortunately the calipers I bought did not come with these bolts so I had to grab them from a local dealer)
My total cost = $330 +/-
I should have taken pics of the install and done a writeup so my bad there. A couple notes:
*The LS1 front brake rotors are 12" vs. 11" for LT1. The LS1 calipers are dual piston vs single piston for LT1.
*I was able to use the stock LT1 brake lines. I did not need to bend the bracket. My car is lowered on coilovers so it is lower than most. If your car is not lowered or not lowered up to 2" like mine, I cannot guarantee you will be able to reuse the stock lines. The LS1 brake lines I received with my calipers were the same length as stock FWIW. Just to note, I think C5 lines are longer IIRC.
*The install was easy, probably took me 3 hours total maybe 4. I am **** so I clean things along the way and take the time to do things right.
*A lot of folks seem to do the C5 front brake upgrade as well. I considered but for literally 2-3x the cost, the difference in braking isn't worth it unless you road race the car IMO. I wanted the calipers to look as factory as possible, didn't want my calipers to read "Corvette". Not knocking them in any way, for me the LS1 swap made better sense, after all there's a C5Z sitting next to my WS6 in the garage so no hate here
LS1 setup on left, LT1 on right:
Before:
After:
Before:
After:
What I bought:
Before:
After:
Before:
After:
Im about to pull the trigger on the vette brakes conversion... Im also concerned with the possible need adjusting or upgrading the rears as well... soo... the consensus seems to be its not going to be a problem... any nay sayers to that? Are ls1 rear brakes bigger?
If you put LS rears in the car you will NEED to use the LS master. But even with Vette fronts and LT tears you can continue to use the stock LT master. The LS camaro calipers are actually the same as the base c5 caliper, only the rotor is larger.
It's truly amazing how much better the car stops once you do the swap.
I have the LS rears and fronts but still have the LT/(V6 technically) master on my car. I do have ABS deleted with a proportioning valve so that might alleviate any issues that would have arised.
The weight loss is nice, but IIRC you can't run 15" skinnies with the LS front brakes .
Worth mentioning for a drag car or street/strip build that sees a lot of track time.
"LS1" rear brakes with LT1 MC here as well. I would be one of those that debates the need for the 98-02 MC. I only did the rears because I got them for free practically. They're not needed at all to balance the bias, there are plenty of others running "LS1" fronts only.
This is true, I have Prostar skinnies on the front of my car that I bought from my buddy with an LS camaro, they fit just fine on his car.
