Lt1 replaced opti now problem!?
Old 03-09-2015, 11:48 AM
94formular's Avatar
Default Lt1 replaced opti now problem!?
Hey guys have a problem with my 94 m6 lt1. Just replaced the distributor and coolant temp sensor on the water pump. Car was sputtering and bucking under hesitation before now when it idles, it idles super rough jumps around on the rpm but doesn't stall until you start driving. Took it for a spin a day ago and under the load car runs fine but when you start off gotta give it a ton of has for it not too stall and the idle is bad. Don't know what it could be replacing the water pump tomorrow and got a new coolant temp sensor, don't think that will resolve the issue but been wanting to replace the pump so doing that, any ideas? Thanks
Old 03-10-2015, 09:28 AM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
What kind of distributor did you use?
Old 03-10-2015, 10:46 AM
LT1_383_Stroker's Avatar
Make sure that your elbow is on correctly. Make sure all the lines after the MAF are installed correctly.
Old 03-10-2015, 11:20 AM
94formular's Avatar
Kmj distributor non vented
Old 03-10-2015, 11:21 AM
94formular's Avatar
Ya man everything's on correctly I took that think off bout 5 times after and everything's on right
Old 03-10-2015, 11:34 AM
BALLSS's Avatar
assuming you installed it correctly and plug wires are on right and all sensors hooked up....the above opti is a very likely candidate for problem
use a AC Delco or Delphi opti
Old 03-10-2015, 12:22 PM
Village Troll
SS RRR's Avatar
Any backfiring?
Old 03-10-2015, 03:49 PM
94formular's Avatar
Ya checked wires bout 5 times all Hooked up in correct orders, don't think it is cause I drove it around the block and when you get on it no hesitation at all. Just on idle very difficult to start moving cause Rpms bounce
Old 03-10-2015, 03:50 PM
94formular's Avatar
Originally Posted by SS RRR
Any backfiring?
No backfiring, doesn't seem like it's misfiring best way to explain it is that it sounds like when a car is leaking air the rpms constantly go up and down, but I don't think it is I did a smoke test and nothing as well.
Quick Reply: Lt1 replaced opti now problem!?
