Vacuum line breaks
Vacuum line breaks
Hey guys I have a 94 lt1 Camaro. Until I can afford to do the ls swap (gonna be a while) that I really want to do I'm trying to get my lt1 running good. I have a problem with rough idle on warm days, I have found a couple broken vacuum lines and don't know where they go, I also have the common 90 elbow coming from the evap purge valve to the throttle body. I know I can use a spark plug boot the fix that. But can anyone tell me where these lines run. In the first picture that same line runs through the driver side strut tower with the fuel lines. In the second picture the line runs from the bottom of the purge valve along the passenger side of the intake manifold then down below the t/b and is broke right below the t/b. Thanks in advance! If this is a thread already I'm sorry, I couldn't find it anywhere.
