Its Alive :)
Old 04-09-2015, 09:54 AM
Chopstix's Avatar
Default Its Alive :)
almost completed with the current build...still have a few minor things to button up and it will be off to the dyno and then the track
Old 04-09-2015, 03:25 PM
ahritchie's Avatar
Sounds pretty nasty....what sort of ET are you aiming for in this beast?
Congrats! It's always a rush to hear it run for the first time!
Old 04-09-2015, 04:03 PM
myltwon's Avatar
Bad ***
Old 04-09-2015, 08:39 PM
Chopstix's Avatar
I hope it at least runs 12s
don't want to get my hopes up to high...I do have a goal in mind but need to get the bugs out of it before I really start leaning on it to see if its capable of doing what I built it to do
Old 04-09-2015, 08:50 PM
waltsfastz's Avatar
Nice, Sounds good
Old 04-10-2015, 01:42 AM
Moderator
BizZzatch350's Avatar
Awesome Ray, glad you're back at it.
Old 04-10-2015, 06:32 AM
Puck's Avatar
She sounds real good, glad to see it running again
Old 04-10-2015, 02:17 PM
Chopstix's Avatar
thx guys...kids are a bit older now...so should have more time to devote to the car again...the car needed a lot of attention from not having the funds...everything is fresh on this build...should put a hurting on the local LS/mustang crowd
Old 04-10-2015, 02:28 PM
KW Baraka's Avatar
Originally Posted by Chopstix
.....everything is fresh on this build.....
What compression ratio are you running?
KW
Old 04-10-2015, 02:37 PM
Chopstix's Avatar
11:1...a bit lower than I would have liked....but new pistons were not in the budget
Old 04-10-2015, 03:59 PM
Puck's Avatar
No worries, pump gas CR just means its automatically a street car no matter what .
Old 04-10-2015, 04:36 PM
Chopstix's Avatar
this car is a "street" car...it will have tags/inspection/etc etc....couldn't make the black car street legal anymore so stuffed the go fast goodies in a different body.
The black car is going under the knife for some much needed chassis upgrades...might move everything back and try for 8s
Old 04-11-2015, 03:27 PM
97 6speed z's Avatar
Question
Did you have to run a small base circle cam with your 396 set up? Care to share the actual cam specs? Also, what rods and pistons did you use?
Old 04-11-2015, 05:31 PM
MonmouthCtyLS7's Avatar
She sounds great!
Old 04-17-2015, 08:56 PM
noer's Avatar
Sounds really good. Grats
Old 04-19-2015, 12:49 PM
flyinZ's Avatar
Cool!
Quick Reply: Its Alive :)
