What Are These Seals For?
Old 04-09-2015, 08:01 PM
1quickTransAm's Avatar
Default What Are These Seals For?
I bought the Fel-Pro bottom end gasket kit for my 383 LT1 build, but what are these large and small o-ring type seals for? I don't recall anything like them during the tear down.
Old 04-09-2015, 08:10 PM
LLLosingit's Avatar
Haven't messed with an LT1 in a while but I think the large go between the block and oil filter adapter. Not sure about the others.
Old 04-09-2015, 09:12 PM
guppymech's Avatar
The two small o-rings are most likely for the water pump coupling to keep the spline grease in it.
Old 04-09-2015, 09:38 PM
I've got an electric WP so good there.
Old 04-10-2015, 07:57 AM
93M6Formula's Avatar
Yep the small ones are for the waterpump driveshaft. The larger one looks like the seal for the factory oil cooler on 93-95ish LT1s. Goes in between the block and the cooler.
Old 04-10-2015, 08:58 AM
I don't have an oil cooler so I am good there too. That does make sense as they are the same size as the oil filter area.
Old 04-10-2015, 11:52 AM
Spartan7's Avatar
The bigger o-rings look like the ones that come in the oil pan gasket kit. I didn't use them. They might be for the oil cooler.
Old 04-10-2015, 12:16 PM
Yes because the oil cooler is part of the oil filter setup. In this order.
Block-Gasket-Cooler-Gasket-Oil Filter. But since you don't have one, you just need that paper gasket (the one you show in between the timing cover gasket) that goes behined the oil filter plate and then obviously your oil filter has it's own gasket.
Old 04-10-2015, 10:06 PM
97REaper's Avatar
I thought those two black o rings were for the opti shaft into the cam?
Old 04-12-2015, 12:39 PM
Nope, they go on the water pump shaft and the drive shaft. They are there to hold in grease for the splines.
Quick Reply: What Are These Seals For?
